![]() | Caution - Install an A239A power supply, labeled for upright installation, in the server. The A239A power supply correctly exhausts air from the rear of the server. Do not install an A239 power supply, which might cause the server to overheat and shut down. |
See Release the CMA.
Do not allow the CMA to hang unsupported while it is unattached.
Service Action Required LED on the power supply
Front and rear Service Action Required LEDs
Rear PS Failure LED on the bezel of the server
See Interpreting LEDs.
