Go to main content
oracle home
SPARC T5-2 Server Service Manual
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
SPARC T5-2 Server Documentation Library
Servicing Fan Modules
Fan Module LEDs
Updated: February 2019
Document Information
Using This Documentation
Product Documentation Library
Feedback
Identifying Components
Front Panel Components (Service)
Rear Panel Components (Service)
Internal System Cables
Related Information
Internal Component Locations
Motherboard Component Locations
I/O Component Locations
Power Distribution and Fan Module Component Locations
System Schematic
Component Task Reference
Detecting and Managing Faults
Understanding Diagnostics
Diagnostics Process
Tool Availability
Log In to Oracle ILOM (Service)
Oracle ILOM Service-Related Tools
Interpreting LEDs
Front Panel Controls and LEDs
Rear Panel Controls and LEDs
Configuring POST
POST Overview
Oracle ILOM Properties That Affect POST Behavior
Configure POST
Run POST With Maximum Testing
Managing Faults
PSH Overview
Check for Faults
Clear a Fault
Interpreting Log Files and System Messages
Check the Message Buffer
View Log Files (Oracle Solaris)
View Log Files (Oracle ILOM)
Preparing for Service
Safety Information
Safety Symbols
ESD Measures
Antistatic Wrist Strap Use
Antistatic Mat
Tools Needed For Service
Filler Panels
Find the Server Serial Number
Locate the Server
Component Service Categories
Removing Power From the Server
Prepare to Power Off the Server
Power Off the Server (Oracle ILOM)
Power Off the Server (Power Button - Graceful)
Power Off the Server (Emergency Shutdown)
Disconnect Power Cords
Accessing Server Components
Prevent ESD Damage
Extend the Server to the Service Position
Release the CMA
Remove the Server From the Rack
Remove the Top Cover
Attachment of Devices During Service
Servicing Drives
Drive LEDs
Locate a Faulty Drive
Remove a Drive
Remove a Drive Filler Panel
Install a Drive
Install a Drive Filler Panel
Verify Drive Functionality
Fan Module LEDs
Locate a Faulty Fan Module
Remove a Fan Module
Install a Fan Module
Verify Fan Module Functionality
Servicing Power Supplies
Power Supply LEDs
Locate a Faulty Power Supply
Remove a Power Supply
Install a Power Supply
Verify Power Supply Functionality
Servicing Memory Risers and DIMMs
Memory Riser and DIMM FRU Names
Memory Riser and DIMM Configuration
DIMM Rank Classification Labels
Locate a Failed DIMM (LEDs)
Locate a Failed DIMM (Oracle ILOM)
Remove a Memory Riser and DIMM
Install a DIMM and a Memory Riser
Enable and Verify Newly Installed DIMMs
Servicing the DVD Drive
Remove a DVD Drive
Install a DVD Drive
Servicing the Battery
Remove the Battery
Install the Battery
Servicing PCIe Cards
PCIe Card Configuration
I/O Root Complex Connections
Remove a PCIe Card or Filler Panel
Install a PCIe Card or Filler Panel
Servicing the SP
SP Firmware and Configuration
Remove the SP
Install the SP
Verify SP Functionality
Servicing the Fan Board
Remove the Fan Board
Install the Fan Board
Verify Fan Board Functionality
Servicing the Motherboard
Remove the Motherboard
Install the Motherboard
Reactivate RAID Volumes
Verify Motherboard Functionality
Servicing the Drive Backplane
Remove the Drive Backplane
Install the Drive Backplane
Verify Drive Backplane Functionality
Servicing the PS Backplane
Remove the PS Backplane
Install the PS Backplane
Verify PS Backplane Functionality
Replace the Top Cover
Return the Server to the Normal Operating Position
Attach Power Cords
Power On the Server (Oracle ILOM)
Power On the Server (Power Button)
Glossary
Index
Index Numbers and Symbols
Index A
Index B
Index C
Index D
Index E
Index F
Index G
Index H
Index I
Index L
Index M
Index N
Index O
Index P
Index R
Index S
Index T
Index U
Index V
Language:
English
Fan Module LEDs
LED
Color
Status When Lit
Power OK
Green
The server is powered on and the fan module is functioning correctly.
Service Required
Amber
The fan module is faulty.
Related Information
Previous
Next
