Go to main content
SPARC T5-2 Server Service Manual
Exit Print View
Updated: February 2019
Replace the Top Cover
  1. Place the top cover on the chassis (panel 1).
    A metal air baffle is attached to the rear inside surface of the top cover. When you place the top cover on the server, ensure that the air baffle does not catch on anything inside the server.
    Set the cover down so that it is about 1 inch (2.5 cm) forward of the rear of the server.
  2. Slide the top cover toward the rear of the chassis until the rear cover lip engages with the rear of the chassis.
  3. Close the top cover by pressing down on the cover with both hands until both latches engage.
    image:Figure showing installation of the top cover.
Related Information
