Remove the Fan Board
 | Caution - These procedures
require that you handle components that are sensitive to ESD. This
sensitivity can cause the component to fail. To avoid damage, ensure that
you follow antistatic practices as described in ESD Measures. |
This is a cold-service procedure that must be performed by
qualified service personnel. The server must be completely powered
down before performing this procedure. See Component Service Categories for more information about this
category of service procedures.
- Prepare
for servicing.
- Attach an antistatic
wrist strap.
- Power off the server and unplug
power cords from the power supplies.
See Removing Power From the Server.
- Extend the server to the maintenance
position.
See Extend the Server to the Service Position.
- Remove the top cover.
See Remove the Top Cover.
- Remove all fan modules.
See Remove a Fan Module.
- Remove all memory risers.
See Remove a Memory Riser and DIMM.
- Disconnect any cables plugged
into the USB or video connectors on the front of the server.
- Remove the fan board.
- Loosen the three captive
screws connecting the front memory riser guide to the motherboard
(panel 1).
- Remove the two screws on each
side of the outside of the chassis that hold the fan board in place
and unplug the fan board and power cables from motherboard (panel
2).
- Remove the front memory riser
guide by pulling it up and out of the chassis (panel 3).
- Pull the fan board back and out
of chassis (panel 4).
The circuit board and the fan holder portions of the fan board
should remain together.
- Install a new fan board.
See Install the Fan Board.
