- Remove
the drive backplane.
See Remove the Drive Backplane.
- Unpack the replacement drive backplane
and place it on an antistatic mat.
- Insert the drive backplane into
the chassis.
Verify that the drive backplane is seated properly at the
bottom, in the small slot near the DVD drive.
- Lift up the metal hook and press
the drive backplane to the front until it snaps into place.
- Replace the power cable, ribbon
data cable, and SAS cables to their original locations.
Note - You must insert the mini-SAS plug into the upper mini-SAS
connector on the drive backplane. This short cable connects the
DVD drive to its USB bridge on the motherboard. The longer SAS cable
connects drive bays 4 and 5 to a storage device in the rear of the
server. The lower mini-SAS connector on the disk backplane requires the
standard, four-channel mini-SAS cable for drive bays 0 to 3.
- Replace the System Remind button
assembly (air divider).
- Replace all memory risers you
removed.
See Install a DIMM and a Memory Riser.
- Replace the DVD drive.
See Install a DVD Drive.
- Replace all drives and filler
panels.
See Install a Drive.
- Return the server to operation.
- Install the top cover.
See Replace the Top Cover.
- Return the server to the normal
operating position.
See Return the Server to the Normal Operating Position.
- Power on the server.
See Returning the Server to Operation.
Note - Authorized service personnel might need to reprogram
the product serial number on the drive backplane. This number is
used for service entitlement and warranty coverage. The correct
product serial number is located on a label on the front of the
chassis.
