/HOST keyswitch_state |
normal |
The server can power on and run POST
(based on the other parameter settings). This parameter overrides
all other commands. |
diag |
The server runs POST based on predetermined settings. |
standby |
The server cannot power on. |
locked |
The server can power on and run POST,
but no flash updates can be made. |
off |
POST does not run. |
normal |
POST runs according to diag level value. |
max |
If diag mode=normal,
runs all the minimum tests plus extensive processor and memory tests. |
min |
runs minimum set of tests. |
none |
Does not run POST on reset. |
hw-change |
(Default) Runs POST following a FRU replacement
or an AC power cycle. |
hw_change_level |
hw_change_verbosity |
min (default) – Displays
the minimum level of output.
max – Displays information
for each step.
normal – Displays a moderate amount of information,
including component names and test results.
debug – Displays extensive
debugging information.
none – Disables the
output.
power-on-reset |
Runs POST on every power on. |
power_on_level |
power_on_verbosity |
for each step.
none – Disables the
output.
error-reset |
(Default) Runs POST if fatal errors are
detected. |
error_reset_level |
error_reset_verbosity |
for each step.
normal – Displays
a moderate amount of information, including component names and test
results.
none – Disables the
output.
all-resets |
Runs POST after any reset. |
normal |
Displays all test and informational messages
in POST output. |
min |
Displays functional tests with a banner
and pinwheel in POST output. |
max |
Displays all test, informational, and
some debugging messages in POST output. |
debug |
Displays extensive debugging information. |
none |
Does not display POST output. |
