Find the Server Serial Number
You need the serial number of the server's chassis
to obtain technical support for the system.
Note - When a PDB, fan board, or drive backplane is replaced,
the chassis serial number and part number might need to be programmed
into the new component. This must be done in a special service mode
by trained service personnel.
- Locate
the serial number using one of the following methods:
- Read the serial
number from a sticker located on the front of the server or another
sticker on the side of the server.
- At the Oracle ILOM prompt type:
-> show /System
/System
Targets:
In the output look for a line under Properties that identifies
the product serial number. For example:
product_serial_number = BDL1026F8F
