A customer can perform this procedure. The server must be completely powered down before performing this procedure. See Component Service Categories for more information about cold-service procedures.
![]() | Caution - Whenever you remove the DVD drive, you must replace it with another DVD drive. Otherwise the server might overheat due to improper airflow. |
See Install a DVD Drive.
