-> start SP/faultmgmt/shell Are you sure you want to start the faultmgmt shell (y/n)? y faultmgmtsp>
If a fault was detected, the server is not operating normally.
See Diagnostics Process.
If no fault was detected, the DIMM was installed successfully.
