The levers should click into place when the module is fully seated in the server.
The following message is delivered over the serial management port.
Unrecognized Chassis: This module is installed in an unknown or unsupported chassis. You must upgrade the firmware to a newer version that supports this chassis.
Refer to the Oracle ILOM documentation for network configuration instructions.
Follow the firmware download instructions in the Oracle ILOM documentation.
