Go to main content
SPARC T5-8 Server Service Manual
Exit Print View
Updated: February 2019
Oracle ILOM Service-Related Tools
You can use these Oracle ILOM shell commands when performing service-related tasks.
Oracle ILOM Command
Description
help [command]
Displays a list of all available commands with syntax and descriptions. Specifying a command name as an option displays help for that command.
set /HOST send_break_action=break
Takes the host server from the OS to either kmdb or OpenBoot prompt (equivalent to a Stop-A), depending on the mode in which the Oracle Solaris OS was booted.
start /HOST/console
Connects to the host.
show /HOST/console/history
Displays the contents of the host's console buffer.
set /HOST/bootmode property=value
Controls the method of booting for the host server's firmware. The value of property can be state, config, or script.
stop /System
or stop /SYS
Powers off the host server.
start /System
or start /SYS
Powers on the host server.
reset /System
or reset /SYS
Generates a hardware reset on the host server.
reset /SP
Reboots the SP.
Related Information
