The SPARC T5-8 server supports single-wide and double-wide card carriers. The installation steps are the same for both carrier widths. This topic includes illustrations only for the single-wide carrier.
![]() | Caution - This procedure involves handling circuit boards that are extremely sensitive to static electricity. Ensure that you follow ESD preventative practices to avoid damaging the circuit boards. See Prevent ESD Damage. |
![]() | Caution - Do not press on the PCIe back panel, or force the PCIe card carrier into the card cage. |
Rotate the handle up until it latches into place.
If you replaced or installed a PCIe card in a server that is running (if you hot-swapped the card), go to Step 6.
If you replaced or installed a PCIe card in a powered-down server, power on the server using the instructions provided in Returning the Server to Operation, then go to Step 7.
See Verify the PCIe Card.
