Exit Print View
See Log In to Oracle ILOM (Service).
-> start SP/faultmgmt/shell Are you sure you want to start the faultmgmt shell (y/n)? y faultmgmtsp>
If a fault was detected, see Diagnostics Process.
If no fault was detected, the rear chassis subassembly is operating normally.
Remove the Rear Chassis Subassembly
Install the Rear Chassis Subassembly
