Green System OK LED – illuminated
Amber System Fault LED – not illuminated
Amber System Fan Fault LED – not illuminated
See Front Panel Controls and LEDs and Rear Panel Controls and LEDs for the LED locations.
If these conditions are not met, perform the actions described in Diagnostics Process.
-> start SP/faultmgmt/shell Are you sure you want to start the faultmgmt shell (y/n)? y faultmgmtsp>
If a fault was detected, see Diagnostics Process.
If no fault was detected, the fan module was installed successfully.
