The following LEDs are lit when a power supply fault is detected:
System Service Required LEDs on the front panel and rear I/O module
Fault LED on the faulty power supply
See Interpreting LEDs.
When the power cord is connected to the server, the associated AC power connector is lit (green), indicating that the power cord is connected to an AC wall socket and is supplying power to the AC power connector.
