The Fabric Interconnect F1-4 is a 2 rack-unit Fabric Interconnect with capacity for 4 I/O modules and either 24 InfiniBand server connections at DDR speeds, or 20 InfiniBand server connections at QDR speeds.
![]() | Caution - The Fabric Interconnect chassis weighs 45 - 53 pounds (20 - 24 kilograms) depending on its configuration. Removing the chassis from the shipping container and installing it in an equipment rack requires a minimum of two people. Attempting to unpack and install this system alone could result in equipment damage or personal injury. |
To unpack the system, you will need the following tools:
#2 Phillips (cross-head) screwdriver
Box cutter
Follow this procedure for unpacking your Fabric Interconnect:
Figure 4 Unpacking Shipping Containers and Examining Contents
