This chapter describes the basic service tasks including installation and removal of field-replaceable components. These instructions are provided for informational purposes only, and should not be followed by anyone who has not received training from Oracle.
The field-replaceable components are:
Fans. See Removing Fan Modules
Power supplies. See Removing Power Supplies
Fabric board, which can be a field replacement of the same type of Fabric Board, or a field upgrade to a different type of Fabric Board:
See Replacing a Fabric Board (field replacement)
See Upgrading a DDR Fabric Board to a QDR Fabric Board (field upgrade)
I/O modules (Ethernet, Gigabit Ethernet, and Fibre Channel). See Removing and Installing I/O Modules.If you are upgrading an existing 10:
If you are upgrading from an existing 10 GE module or 10-Port GE module to the 4-Port 10 GE module, follow the procedure documented in Upgrade to a 4-Port 10 GE Module.
Management module. See Removing and Installing the Management Module.
Front panel assembly (includes SCP board). See Removing and Installing the Front Panel Assembly
Replacing an FP-1 (previous generation Front Panel) with an FP-2 (current generation). See Replacing an FP-1 Front Panel with an FP-2 Front Panel
The Fabric Interconnect also supports a locator LED to indicate a Fabric Interconnect. See The ID LED
![]() | Caution - All of the Fabric Interconnect chassis components must be installed or removed by a qualified service technician. For customer training and service information, contact Oracle Customer Support. |
![]() | Caution - To prevent electric shock, do not remove the cover. No user-serviceable parts inside. This equipment contains hazardous voltages and should only be opened by a trained and qualified technician. |
