The Fabric Interconnect F1-4 Management module has a dedicated, half-height slot in the upper right corner of the rear of the chassis.
The Fabric Interconnect F1-4 Management module is not a field-serviceable part, which is why it has no handle, and is securely screwed into the chassis.
Caution - Do not attempt to remove or replace the Management Module for a Fabric Interconnect F1-4. If your Fabric Interconnect F1-4 Management module requires service, contact Oracle Customer Support for information about completing the service. |
