Unpack the Fabric Interconnect
F1-15
The Fabric Interconnect F1-15 is a 4 rack-unit
Fabric Interconnect with capacity for 15 I/O modules and either
24 InfiniBand server connections at DDR speeds, or 20 InfiniBand
server connections at QDR speeds.
![Caution Caution](graphics/caution.gif) | Caution - The Fabric Interconnect chassis
weighs 100 - 130 pounds (45 - 59 kilograms) depending on its configuration.
Removing the chassis from the shipping container and installing
it in an equipment rack requires a minimum of two people. Attempting
to unpack and install this system alone could result in equipment damage
or personal injury. |
To unpack the system, you will need the following tools:
#2 Phillips (cross-head) screwdriver
Box cutter
Note - Because the number and types of I/O modules are determined
by the customer, I/O modules are shipped in separate boxes.
Follow this procedure for unpacking your Fabric Interconnect:
- Locate
the shipping list and verify that the following containers are present:
- System shipping
container
- I/O module box (1 to 15)
- HCA box
- Options box
- Rail Kit box
- Accessory Kit
- System information packet
- Open the containers and verify
their contents against the illustration in Unpacking Shipping Containers and Examining Contents.
Figure 3 Unpacking Shipping Containers
Note - Although not pictured, a cable management assembly (CMA)
is included in a separate box. In addition, a module retention bracket
(also not shown) is attached to the F1-15 chassis to keep modules
and blanks secure while shipping. The CMA can be installed as an
option (see
Installing the Cable Management Assembly. However, to install
I/O Modules, you must remove the module retention bracket.
- Unpack the Fabric Interconnect
chassis and place it on a flat, stable surface capable of supporting
up to 170 pounds (77.11kg).
