Some data centers have strict security requirements—for example, they prohibit any device that can be used to remove data from the premises, such as a USB thumbstick. The Management Module has a USB drive which is useful primarily for recovering the system in the very rare case of a system crash.
Because the USB drive does allow data to be copied off of the Fabric Interconnect to a removable device, it might not comply with the strict data center security requirements. As a result, in XgOS 3.6.0 and later, the USB drive is disabled by default. For new shipments from the factory, the USB is inactive, but some existing Fabric Interconnects that are already deployed might still have the USB active. The USB can be disabled through a software procedure.
Some notes about disabling the USB drive:
Upgrading to Oracle XgOS 3.6.0 or later from a previous version of software does not cause the USB to be deactivated. You must explicitly disable the USB drive by using the procedure in this section.
The procedure for disabling the USB drive is relevant to both models of Oracle Fabric Interconnect.
Disabling the USB device requires entering the Fabric Interconnect BIOS, which might or might not have additional layers of security depending on your department's policies. The procedure in this section assumes that no BIOS security is present. If you have set up BIOS security, make sure to comply with your department's security policies after completing this procedure—for example, reset the BIOS password.
To enter the Fabric Interconnect's BIOS, you will need the following:
Interrupt the Fabric Interconnect's boot up sequence in a timely manner. You have approximately 5 seconds after the Fabric Interconnect starts booting.
If you are watching the console, you will see the BIOS prompt. When you see the prompt, follow the key sequence. If you do not enter the BIOS in a timely manner, you can power off the Fabric Interconnect (for example, remove the power cables) and try again.
A remote terminal connection (for example, hyperterminal) that uses ANSI encoding. By default, when you connect to the Serial 1 port (SER-1) on the Management Module, the terminal session requires VT100 encoding. However, the BIOS is a special case. In order to enter the Fabric Interconnect BIOS, the terminal connection must be set to ANSI encoding.
When the reboot is complete, the USB drive on the Management Module is no longer active.
