Remove Fabric Interconnect F1-4 Fan Modules
Fabric Interconnect F1-4 fan modules are located on the front of the chassis.
To remove a Fabric Interconnect F1-4 fan module, follow this procedure:
Use a Phillips screwdriver to release the two spring-loaded securing
screws located at the top corners of the each fan module (1). See Removing a Fabric Interconnect F1-4 Fan Module.
Figure 63 Removing a Fabric Interconnect F1-4 Fan Module
Grasp the handle and slide the fan module out of the chassis (2).
