The ID LED can be controlled through software or through the ID button. To activate the ID LED, follow this procedure:
set system id-led on
When you issue this command, the amber ID LED illuminates. The service technician should be able to locate the Fabric Interconnect by looking for Fabric Interconnect with the glowing amber LED.
admin@nerf [ovn] show chassis detail ----------------------------------------------------------------- dn chassis mod descr nerf id 1 type chassisIb15Slot model-num XC1DH41ZZZ-1 part-num 705-00005-01 part-num-major 01 part-num-minor 05 assembly-id 715-00005-01 assembly-id-major 01 assembly-id-minor 05 serial-num 050610240 manufacture-date 01-03-2006 mac-addr 00:13:97:01:80:00 mac-addr-mask 12 wwn 50:01:39:70:00:00:80:00 wwn-mask 12 locator-led-on false num-of-io-slots 15 phone-home true phone-home-notification false strip-private true snd-alarms true copyurl barkely.xsigo.com:5000 customer-name Customer XYZ contact-email-addr dude1@xsigo.com contact-phone-nums 800 111 2222, 333 333 3333 httpproxy-host ubb httpproxy-user proxyuser1 httpproxy-password passproxy httpproxy-port 3128 phone-home-frequency weekly ------------------------------------------------------------------------------- 1 record displayed
In this example, the bold text highlights the current state of the ID LED. True indicates that the LED is on (illuminated), and false indicates that the LED is off (dark).
set system id-led off
