Make sure that the Fabric Board handles are in the open position, not flat against the faceplate.
Figure 73 Inserting the Fabric Interconnect F1-4 Fabric Board
When the Fabric Board is almost completely inserted, you will feel some resistance when the connector at the rear of the Fabric Board contacts its socket on the inside of the chassis.
![]() | Caution - Make sure to pivot the Fabric Board handles in a horizontal plane. Do not apply upward or downward pressure on the Fabric Board's handles when you are installing the Fabric Board. You need to pivot the Fabric Board handles inward until they make contact with the threaded standoff on the Fabric Board's faceplate. |
Figure 74 Securing the Fabric Interconnect F1-4's Fabric Board
