Using the I/O Module Lock
The I/O module lock operates in a 90-degree arc, and the slot in the handle indicates the
position of the module's lock. Figure 1, Table 1, I/O Module Lock Positions shows the positions
for the locking I/O Modules. This locking mechanism is supported on all models of
Fabric Interconnect.
Table 1 I/O Module Lock Positions
Closed/ Locked |
For the Fabric Interconnect F1-15, the
locked position is horizontal (0 degree angle)
For the Fabric Interconnect F1-4, the locked position is vertical
(90 degree angle) |
When the module lock is closed, the module cannot be removed
or inserted. In this position, the module is held in place by a
metal tab that contacts the Fabric Interconnect's frame and
prohibits moving the module around in its slot.
To unlock the module, use a screwdriver to turn the module
handle 90 degrees counter- clockwise until the handle is in the
"open" position.
Open/Unlocked |
open position is vertical (90 degree angle)
For the Fabric Interconnect F1-4, the open position is horizontal
(0 degree angle) |
When the module lock is open, the module can be removed and
inserted. In this position, the module is held in its slot by
only the module socket connecting to the Fabric Interconnect's
midplane.
This position is not supported for runtime operating of any
I/O module. Modules should be unlocked only temporarily, for
example during a module swap, then locked into place for runtime
operation.
To lock the module in place by turning the knob 90 degrees
clockwise until the handle is in the "closed" position.
