Host Channel Adapter (HCA) cards are only required for servers that do not have InfiniBand interfaces. Check the manufacturer's documentation to determine if your server requires an HCA card. If you must install an HCA card, refer to your server's service label or user manual for information.
Different servers have different methods for installing an HCA card. This section documents one HCA installation procedure for a common server. You can use the procedure as a general guideline for installing the HCA card, but Oracle recommends you also consult the documentation from the server's manufacturer for specific installation information.
To install an HCA card, you will need the following equipment:
Various screwdrivers and/or hex-head wrenches (depending on the cable and connector types)
ESD wrist strap
Caution - Observe proper ESD procedures when handling HCA cards. |
