This chapter guides you through the initial setup and configuration of Oracle Fabric Interconnect. The setup procedure is offered as an example of a typical, basic configuration and is not intended to be a comprehensive reference.
This chapter documents the following topics:
Log in to the Oracle Fabric Interconnect through the serial port and perform the initial system configuration using the Oracle Configuration Wizard. See Run the Oracle Configuration Wizard.
Change the Oracle Fabric Interconnect's root password. See Change the Root Password.
You will also need to install host drivers on the host server(s) in your network. For more information, refer to the following guides:
Oracle Virtual Networking for ESX Hosts Installation and Boot Guide
Oracle Virtual Networking for Oracle Solaris Hosts Installation and Boot Guide
Oracle Virtual Networking for Windows Hosts Installation and Boot Guide
