Remove a Fabric Interconnect F1-4 Front Panel Assembly
To remove a Fabric Interconnect F1-4 front panel assembly, you will need a #2
Phillips-head screwdriver.
To remove a Fabric Interconnect F1-4 front panel, follow this
procedure:
Power down the Fabric Interconnect.
Using the screwdriver, release the two spring-loaded screws (1) that
secure the release levers to the front mounting brackets. See Removing the Fabric Interconnect F1-4 Front Panel Assembly.
Figure 98 Removing the Fabric Interconnect F1-4 Front Panel Assembly
When the screws are loose, gently lift the lever arms in a 90 degree
upward arc (2) as shown in Removing the Fabric Interconnect F1-4 Front Panel Assembly. When both arms are lifted, you should feel the
Front Panel disengage from the chassis.
Holding the lever arms, apply even pressure to both handles and slide the
Front Panel towards you (3) until it is completely removed from the Fabric
Interconnect F1-4.
