Make sure that the I/O Module is oriented so that the sheet metal side is facing down and the module's faceplate is facing you.
Figure 94 Installing a Fabric Interconnect F1-4 I/O Module
When the I/O Module is almost completely inserted, you will feel some resistance, which is the I/O Module's connector meeting its midplane socket. Continue to apply gentle pressure until the connector is seated in the socket.
