CURLINFO_SPEED_UPLOAD - get upload speed
#include <curl/curl.h> CURLcode curl_easy_getinfo(CURL *handle, CURLINFO_SPEED_UPLOAD, double *speed);
CURLINFO_SPEED_UPLOAD(3) curl_easy_getinfo options CURLINFO_SPEED_UPLOAD(3)
NAME
SYNOPSIS
DESCRIPTION
Pass a pointer to a double to receive the average upload speed that
curl measured for the complete upload. Measured in bytes/second.
CURLINFO_SPEED_UPLOAD_T(3) is a newer replacement that returns a more
sensible variable type.
PROTOCOLS
EXAMPLE
CURL *curl = curl_easy_init();
if(curl) {
curl_easy_setopt(curl, CURLOPT_URL, "https://example.com");
/* Perform the request */
res = curl_easy_perform(curl);
if(!res) {
double speed;
res = curl_easy_getinfo(curl, CURLINFO_SPEED_UPLOAD, &speed);
if(!res) {
printf("Upload speed %.0f bytes/sec\n", ul);
AVAILABILITY
Added in
RETURN VALUE
Returns CURLE_OK if the option is supported, and CURLE_UNKNOWN_OPTION
if not.
ATTRIBUTES
See attributes(7) for descriptions of the following attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | web/curl |
|Stability | Uncommitted |
SEE ALSO
curl_easy_getinfo(3), curl_easy_setopt(3), CURLINFO_SPEED_DOWNLOAD(3),
NOTES
Source code for open source software components in Oracle Solaris can
be found at https://www.oracle.com/downloads/opensource/solaris-source-
code-downloads.html.
This software was built from source available at
https://github.com/oracle/solaris-userland. The original community
source was downloaded from https://curl.se/down-
load/curl-7.83.1.tar.bz2.
Further information about this software can be found on the open source
community website at http://curl.haxx.se/.
libcurl 7.83.1 November 26, 2021 CURLINFO_SPEED_UPLOAD(3)
