CURLMOPT_MAX_PIPELINE_LENGTH - maximum number of requests in a pipeline
#include <curl/curl.h> CURLMcode curl_multi_setopt(CURLM *handle, CURLMOPT_MAX_PIPELINE_LENGTH, long max);
curl_multi_setopt options CURLMOPT_MAX_PIPELINE_LENGTH(3) NAME CURLMOPT_MAX_PIPELINE_LENGTH - maximum number of requests in a pipeline SYNOPSIS #include <curl/curl.h> CURLMcode curl_multi_setopt(CURLM *handle, CURLMOPT_MAX_PIPELINE_LENGTH, long max); DESCRIPTION No function since pipelining was removed in 7.62.0. Pass a long. The set max number will be used as the maximum amount of outstanding requests in an HTTP/1.1 pipelined connection. This option is only used for HTTP/1.1 pipelining, not for HTTP/2 multiplexing. When this limit is reached, libcurl will use another connection to the same host (see CURLMOPT_MAX_HOST_CONNECTIONS(3)), or queue the request until one of the pipelines to the host is ready to accept a request. Thus, the total number of requests in-flight is CURLMOPT_MAX_HOST_CON- NECTIONS(3) * CURLMOPT_MAX_PIPELINE_LENGTH(3). DEFAULT 5 PROTOCOLS HTTP(S) EXAMPLE CURLM *m = curl_multi_init(); /* set a more conservative pipe length */ curl_multi_setopt(m, CURLMOPT_MAX_PIPELINE_LENGTH, 3L); AVAILABILITY Added in 7.30.0 RETURN VALUE Returns CURLM_OK if the option is supported, and CURLM_UNKNOWN_OPTION if not. ATTRIBUTES See attributes(7) for descriptions of the following attributes: +---------------+------------------+ |ATTRIBUTE TYPE | ATTRIBUTE VALUE | +---------------+------------------+ |Availability | web/curl | +---------------+------------------+ |Stability | Uncommitted | +---------------+------------------+ SEE ALSO CURLMOPT_PIPELINING(3), CURLMOPT_MAX_HOST_CONNECTIONS(3), NOTES Source code for open source software components in Oracle Solaris can be found at https://www.oracle.com/downloads/opensource/solaris-source- code-downloads.html. This software was built from source available at https://github.com/oracle/solaris-userland. The original community source was downloaded from https://curl.se/down- load/curl-7.83.1.tar.bz2. Further information about this software can be found on the open source community website at http://curl.haxx.se/. libcurl 7.83.1 November 26, 2021 CURLMOPT_MAX_PIPELINE_LENGTH(3)
