TAP::Parser::Result::Plan - Plan result token.
Please see following description for synopsis
Perl Programmers Reference Guide TAP::Parser::Result::Plan(3) NAME TAP::Parser::Result::Plan - Plan result token. VERSION Version 3.42 DESCRIPTION This is a subclass of TAP::Parser::Result. A token of this class will be returned if a plan line is encountered. 1..1 ok 1 - woo hooo! 1..1 is the plan. Gotta have a plan. OVERRIDDEN METHODS Mainly listed here to shut up the pitiful screams of the pod coverage tests. They keep me awake at night. o "as_string" o "raw" Instance Methods "plan" if ( $result->is_plan ) { print $result->plan; } This is merely a synonym for "as_string". "tests_planned" my $planned = $result->tests_planned; Returns the number of tests planned. For example, a plan of 1..17 will cause this method to return '17'. "directive" my $directive = $plan->directive; If a SKIP directive is included with the plan, this method will return it. 1..0 # SKIP: why bother? "has_skip" if ( $result->has_skip ) { ... } Returns a boolean value indicating whether or not this test has a SKIP directive. "explanation" my $explanation = $plan->explanation; If a SKIP directive was included with the plan, this method will return the explanation, if any. "todo_list" my $todo = $result->todo_list; for ( @$todo ) { ... } ATTRIBUTES See attributes(7) for descriptions of the following attributes: +---------------+-----------------------+ |ATTRIBUTE TYPE | ATTRIBUTE VALUE | +---------------+-----------------------+ |Availability | runtime/perl-532 | +---------------+-----------------------+ |Stability | Pass-through volatile | +---------------+-----------------------+ NOTES Source code for open source software components in Oracle Solaris can be found at https://www.oracle.com/downloads/opensource/solaris-source- code-downloads.html. This software was built from source available at https://github.com/oracle/solaris-userland. The original community source was downloaded from http://www.cpan.org/src/5.0/perl-5.32.0.tar.gz. Further information about this software can be found on the open source community website at https://www.perl.org/. perl v5.32.0 2020-06-14 TAP::Parser::Result::Plan(3)
