CURLOPT_MAX_RECV_SPEED_LARGE - rate limit data download speed
#include <curl/curl.h> CURLcode curl_easy_setopt(CURL *handle, CURLOPT_MAX_RECV_SPEED_LARGE, curl_off_t maxspeed);
curl_easy_setopt options CURLOPT_MAX_RECV_SPEED_LARGE(3) NAME CURLOPT_MAX_RECV_SPEED_LARGE - rate limit data download speed SYNOPSIS #include <curl/curl.h> CURLcode curl_easy_setopt(CURL *handle, CURLOPT_MAX_RECV_SPEED_LARGE, curl_off_t maxspeed); DESCRIPTION Pass a curl_off_t as parameter. If a download exceeds this maxspeed (counted in bytes per second) the transfer will pause to keep the speed less than or equal to the parameter value. Defaults to unlimited speed. This is not an exact science. libcurl attempts to keep the average speed below the given threshold over a period time. If you set maxspeed to a value lower than CURLOPT_BUFFERSIZE(3), libcurl might download faster than the set limit initially. This option does not affect transfer speeds done with FILE:// URLs. DEFAULT 0, disabled PROTOCOLS All but file:// EXAMPLE CURL *curl = curl_easy_init(); if(curl) { CURLcode ret; curl_easy_setopt(curl, CURLOPT_URL, "https://example.com/"); /* cap the download speed to 31415 bytes/sec */ curl_easy_setopt(curl, CURLOPT_MAX_RECV_SPEED_LARGE, (curl_off_t)31415); ret = curl_easy_perform(curl); } AVAILABILITY Added in 7.15.5 RETURN VALUE Returns CURLE_OK if the option is supported, and CURLE_UNKNOWN_OPTION if not. ATTRIBUTES See attributes(7) for descriptions of the following attributes: +---------------+------------------+ |ATTRIBUTE TYPE | ATTRIBUTE VALUE | +---------------+------------------+ |Availability | web/curl | +---------------+------------------+ |Stability | Uncommitted | +---------------+------------------+ SEE ALSO CURLOPT_MAX_SEND_SPEED_LARGE(3), CURLOPT_LOW_SPEED_LIMIT(3), NOTES Source code for open source software components in Oracle Solaris can be found at https://www.oracle.com/downloads/opensource/solaris-source- code-downloads.html. This software was built from source available at https://github.com/oracle/solaris-userland. The original community source was downloaded from https://curl.se/down- load/curl-7.83.1.tar.bz2. Further information about this software can be found on the open source community website at http://curl.haxx.se/. libcurl 7.83.1 October 31, 2021 CURLOPT_MAX_RECV_SPEED_LARGE(3)
