Sun::Solaris::Project - Perl interface to Projects
use Sun::Solaris::Project qw(:ALL); my $projid = getprojid(); This module provides wrappers for the Project-related system calls and the "libproject(3LIB)" library. Also provided are constants from the various Project-related headers. Constants "MAXPROJID", " PROJNAME_MAX", "PROJF_PATH", "PROJECT_BUFSZ", "SETPROJ_ERR_TASK", and "SETPROJ_ERR_POOL". Functions "getprojid()" This function returns the numeric project ID of the calling process or "undef" if the underlying getprojid(2) system call is unsuccessful. "setproject($project, $user, $flags)" If $user is a member of the project specified by $project, "setproject()" creates a new task and associates the appropriate resource controls with the process, task, and project. This function returns 0 on success. If the the underlying task creation fails, "SETPROJ_ERR_TASK" is returned. If pool assignment fails, "SETPROJ_ERR_POOL" is returned. If any resource attribute assignments fail, an integer value corresponding to the offset of the failed attribute assignment in the project database is returned. See "setproject(3PROJECT)". "activeprojects()" This function returns a list of the currently active projects on the system. Each value in the list is the numeric ID of a currently active project. "getprojent()" This function returns the next entry from the project database. When called in a scalar context, "getprojent()" returns only the name of the project. When called in a list context, "getprojent()" returns a 6-element list consisting of: ($name, $projid, $comment, \@users, \@groups, $attr) "\@users" and "\@groups" are returned as arrays containing the appropriate user or project lists. On end-of-file "undef" is returned. "setprojent()" This function rewinds the project database to the beginning of the file. "endprojent()" This function closes the project database. "getprojbyname($name)" This function searches the project database for an entry with the specified name. It returns a 6-element list as returned by "getprojent()" if the entry is found and "undef" if it cannot be found. "getprojbyid($id)" This function searches the project database for an entry with the specified ID. It returns a 6-element list as returned by "getprojent()" if the entry is found or "undef" if it cannot be found. "getdefaultproj($user)" This function returns the default project entry for the specified user in the same format as "getprojent()". It returns "undef" if the user cannot be found. See "getdefaultproj(3PROJECT)" for information about the lookup process. "fgetprojent($filehandle)" This function returns the next project entry from $filehandle, a Perl file handle that must refer to a previously opened file in project(5) format. Return values are the same as for "getprojent()". "inproj($user, $project)" This function checks whether the specified user is able to use the project. This function returns "true" if the user can use the project and "false" otherwise. See "inproj(3PROJECT)". "getprojidbyname($project)" This function searches the project database for the specified project. It returns the project ID if the project is found and "undef" if it is not found. Class methods None. Object methods None. Exports By default nothing is exported from this module. The following tags can be used to selectively import constants and functions defined in this module: :SYSCALLS getprojid() :LIBCALLS setproject(), activeprojects(), getprojent(), setprojent(), endprojent(), getprojbyname(), getprojbyid(), getdefaultproj(), fgetprojent(), inproj(), and getprojidbyname() :CONSTANTS MAXPROJID, PROJNAME_MAX, PROJF_PATH, PROJECT_BUFSZ, SETPROJ_ERR_TASK, and SETPROJ_ERR_POOL :ALL :SYSCALLS, :LIBCALLS, and :CONSTANTS
User Contributed Perl Documentation pod::Project(3) NAME Sun::Solaris::Project - Perl interface to Projects SYNOPSIS use Sun::Solaris::Project qw(:ALL); my $projid = getprojid(); This module provides wrappers for the Project-related system calls and the "libproject(3LIB)" library. Also provided are constants from the various Project-related headers. Constants "MAXPROJID", " PROJNAME_MAX", "PROJF_PATH", "PROJECT_BUFSZ", "SETPROJ_ERR_TASK", and "SETPROJ_ERR_POOL". Functions "getprojid()" This function returns the numeric project ID of the calling process or "undef" if the underlying getprojid(2) system call is unsuccessful. "setproject($project, $user, $flags)" If $user is a member of the project specified by $project, "setproject()" creates a new task and associates the appropriate resource controls with the process, task, and project. This function returns 0 on success. If the the underlying task creation fails, "SETPROJ_ERR_TASK" is returned. If pool assignment fails, "SETPROJ_ERR_POOL" is returned. If any resource attribute assignments fail, an integer value corresponding to the offset of the failed attribute assignment in the project database is returned. See "setproject(3PROJECT)". "activeprojects()" This function returns a list of the currently active projects on the system. Each value in the list is the numeric ID of a currently active project. "getprojent()" This function returns the next entry from the project database. When called in a scalar context, "getprojent()" returns only the name of the project. When called in a list context, "getprojent()" returns a 6-element list consisting of: ($name, $projid, $comment, \@users, \@groups, $attr) "\@users" and "\@groups" are returned as arrays containing the appropriate user or project lists. On end-of-file "undef" is returned. "setprojent()" This function rewinds the project database to the beginning of the file. "endprojent()" This function closes the project database. "getprojbyname($name)" This function searches the project database for an entry with the specified name. It returns a 6-element list as returned by "getprojent()" if the entry is found and "undef" if it cannot be found. "getprojbyid($id)" This function searches the project database for an entry with the specified ID. It returns a 6-element list as returned by "getprojent()" if the entry is found or "undef" if it cannot be found. "getdefaultproj($user)" This function returns the default project entry for the specified user in the same format as "getprojent()". It returns "undef" if the user cannot be found. See "getdefaultproj(3PROJECT)" for information about the lookup process. "fgetprojent($filehandle)" This function returns the next project entry from $filehandle, a Perl file handle that must refer to a previously opened file in project(5) format. Return values are the same as for "getprojent()". "inproj($user, $project)" This function checks whether the specified user is able to use the project. This function returns "true" if the user can use the project and "false" otherwise. See "inproj(3PROJECT)". "getprojidbyname($project)" This function searches the project database for the specified project. It returns the project ID if the project is found and "undef" if it is not found. Class methods None. Object methods None. Exports By default nothing is exported from this module. The following tags can be used to selectively import constants and functions defined in this module: :SYSCALLS getprojid() :LIBCALLS setproject(), activeprojects(), getprojent(), setprojent(), endprojent(), getprojbyname(), getprojbyid(), getdefaultproj(), fgetprojent(), inproj(), and getprojidbyname() :CONSTANTS MAXPROJID, PROJNAME_MAX, PROJF_PATH, PROJECT_BUFSZ, SETPROJ_ERR_TASK, and SETPROJ_ERR_POOL :ALL :SYSCALLS, :LIBCALLS, and :CONSTANTS ATTRIBUTES See attributes(7) for descriptions of the following attributes: ___________________________________________________________ | ATTRIBUTE TYPE | ATTRIBUTE VALUE | |_____________________________|_____________________________| | Availability | CPAN (http://www.cpan.org) | |_____________________________|_____________________________| | Interface Stability | Evolving | |_____________________________|_____________________________| SEE ALSO getprojid(2), "getdefaultproj(3PROJECT)", "inproj(3PROJECT)", "libproject(3LIB)", "setproject(3PROJECT)", project(5), attributes(7) perl v5.32.0 2022-06-28 pod::Project(3)
