TAP::Formatter::Color - Run Perl test scripts with color
use TAP::Formatter::Color; my $harness = TAP::Formatter::Color->new( \%args ); $harness->runtests(@tests);
Perl Programmers Reference Guide TAP::Formatter::Color(3)
NAME
VERSION
Version 3.42
DESCRIPTION
Note that this harness is experimental. You may not like the colors
I've chosen and I haven't yet provided an easy way to override them.
This test harness is the same as TAP::Harness, but test results are
output in color. Passing tests are printed in green. Failing tests
are in red. Skipped tests are blue on a white background and TODO
tests are printed in white.
If Term::ANSIColor cannot be found (and Win32::Console::ANSI if running
under Windows) tests will be run without color.
SYNOPSIS
METHODS
Class Methods
"new"
The constructor returns a new "TAP::Formatter::Color" object. If
Term::ANSIColor is not installed, returns undef.
"can_color"
Test::Formatter::Color->can_color()
Returns a boolean indicating whether or not this module can actually
generate colored output. This will be false if it could not load the
modules needed for the current platform.
"set_color"
Set the output color.
ATTRIBUTES
See attributes(7) for descriptions of the following attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | runtime/perl-532 |
|Stability | Pass-through volatile |
NOTES
Source code for open source software components in Oracle Solaris can
be found at https://www.oracle.com/downloads/opensource/solaris-source-
code-downloads.html.
This software was built from source available at
https://github.com/oracle/solaris-userland. The original community
source was downloaded from
http://www.cpan.org/src/5.0/perl-5.32.0.tar.gz.
Further information about this software can be found on the open source
community website at https://www.perl.org/.
perl v5.32.0 2020-06-14 TAP::Formatter::Color(3)
