TAP::Formatter::Base - Base class for harness output delegates
use TAP::Formatter::Console; my $harness = TAP::Formatter::Console->new( \%args );
Perl Programmers Reference Guide TAP::Formatter::Base(3)
NAME
VERSION
Version 3.42
DESCRIPTION
This provides console orientated output formatting for TAP::Harness.
SYNOPSIS
METHODS
Class Methods
"new"
my %args = (
verbose => 1,
The constructor returns a new "TAP::Formatter::Console" object. If a
TAP::Harness is created with no "formatter" a "TAP::Formatter::Console"
is automatically created. If any of the following options were given to
TAP::Harness->new they well be passed to this constructor which accepts
an optional hashref whose allowed keys are:
o "verbosity"
Set the verbosity level.
o "verbose"
Printing individual test results to STDOUT.
o "timer"
Append run time for each test to output. Uses Time::HiRes if
available.
o "failures"
Show test failures (this is a no-op if "verbose" is selected).
o "comments"
Show test comments (this is a no-op if "verbose" is selected).
o "quiet"
Suppressing some test output (mostly failures while tests are
running).
o "really_quiet"
Suppressing everything but the tests summary.
o "silent"
Suppressing all output.
o "errors"
If parse errors are found in the TAP output, a note of this will be
made in the summary report. To see all of the parse errors, set
this argument to true:
errors => 1
o "directives"
If set to a true value, only test results with directives will be
displayed. This overrides other settings such as "verbose",
"failures", or "comments".
o "stdout"
A filehandle for catching standard output.
o "color"
If defined specifies whether color output is desired. If "color" is
not defined it will default to color output if color support is
available on the current platform and output is not being
redirected.
o "jobs"
The number of concurrent jobs this formatter will handle.
o "show_count"
Boolean value. If false, disables the "X/Y" test count which shows
up while tests are running.
Any keys for which the value is "undef" will be ignored.
"prepare"
Called by Test::Harness before any test output is generated.
This is an advisory and may not be called in the case where tests are
being supplied to Test::Harness by an iterator.
"open_test"
Called to create a new test session. A test session looks like this:
my $session = $formatter->open_test( $test, $parser );
while ( defined( my $result = $parser->next ) ) {
$session->result($result);
exit 1 if $result->is_bailout;
$session->close_test;
"summary"
$harness->summary( $aggregate );
"summary" prints the summary report after all tests are run. The first
argument is an aggregate to summarise. An optional second argument may
be set to a true value to indicate that the summary is being output as
a result of an interrupted test run.
ATTRIBUTES
See attributes(7) for descriptions of the following attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | runtime/perl-532 |
|Stability | Pass-through volatile |
NOTES
Source code for open source software components in Oracle Solaris can
be found at https://www.oracle.com/downloads/opensource/solaris-source-
code-downloads.html.
This software was built from source available at
https://github.com/oracle/solaris-userland. The original community
source was downloaded from
http://www.cpan.org/src/5.0/perl-5.32.0.tar.gz.
Further information about this software can be found on the open source
community website at https://www.perl.org/.
perl v5.32.0 2020-06-14 TAP::Formatter::Base(3)
