CURLOPT_LOW_SPEED_LIMIT - low speed limit in bytes per second
#include <curl/curl.h> CURLcode curl_easy_setopt(CURL *handle, CURLOPT_LOW_SPEED_LIMIT, long speedlimit);
curl_easy_setopt options CURLOPT_LOW_SPEED_LIMIT(3)
NAME
SYNOPSIS
long speedlimit);
DESCRIPTION
Pass a long as parameter. It contains the average transfer speed in
bytes per second that the transfer should be below during CUR-
LOPT_LOW_SPEED_TIME(3) seconds for libcurl to consider it to be too
slow and abort.
DEFAULT
0, disabled
PROTOCOLS
All
EXAMPLE
curl = curl_easy_init();
if(curl) {
curl_easy_setopt(curl, CURLOPT_URL, url);
/* abort if slower than 30 bytes/sec during 60 seconds */
curl_easy_setopt(curl, CURLOPT_LOW_SPEED_TIME, 60L);
curl_easy_setopt(curl, CURLOPT_LOW_SPEED_LIMIT, 30L);
res = curl_easy_perform(curl);
if(CURLE_OPERATION_TIMEDOUT == res) {
printf("Timeout!\n");
/* always cleanup */
curl_easy_cleanup(curl);
AVAILABILITY
Always
RETURN VALUE
Returns CURLE_OK
ATTRIBUTES
See attributes(7) for descriptions of the following attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | web/curl |
|Stability | Uncommitted |
SEE ALSO
CURLOPT_LOW_SPEED_TIME(3), CURLOPT_TIMEOUT(3),
NOTES
Source code for open source software components in Oracle Solaris can
be found at https://www.oracle.com/downloads/opensource/solaris-source-
code-downloads.html.
This software was built from source available at
https://github.com/oracle/solaris-userland. The original community
source was downloaded from https://curl.se/down-
load/curl-7.83.1.tar.bz2.
Further information about this software can be found on the open source
community website at http://curl.haxx.se/.
libcurl 7.83.1 November 26, 2021
