TAP::Harness::Beyond - Beyond make test
Please see following description for synopsis
Perl Programmers Reference Guide TAP::Harness::Beyond(3)
NAME
Test::Harness::Beyond - Beyond make test
Beyond make test
Test::Harness is responsible for running test scripts, analysing their
output and reporting success or failure. When I type make test (or
./Build test) for a module, Test::Harness is usually used to run the
tests (not all modules use Test::Harness but the majority do).
To start exploring some of the features of Test::Harness I need to
switch from make test to the prove command (which ships with
Test::Harness). For the following examples I'll also need a recent
version of Test::Harness installed; 3.14 is current as I write.
For the examples I'm going to assume that we're working with a 'normal'
Perl module distribution. Specifically I'll assume that typing make or
./Build causes the built, ready-to-install module code to be available
below ./blib/lib and ./blib/arch and that there's a directory called
't' that contains our tests. Test::Harness isn't hardwired to that
configuration but it saves me from explaining which files live where
for each example.
Back to prove; like make test it runs a test suite - but it provides
far more control over which tests are executed, in what order and how
their results are reported. Typically make test runs all the test
scripts below the 't' directory. To do the same thing with prove I
type:
prove -rb t
The switches here are -r to recurse into any directories below 't' and
-b which adds ./blib/lib and ./blib/arch to Perl's include path so that
the tests can find the code they will be testing. If I'm testing a
module of which an earlier version is already installed I need to be
careful about the include path to make sure I'm not running my tests
against the installed version rather than the new one that I'm working
on.
Unlike make test, typing prove doesn't automatically rebuild my module.
If I forget to make before prove I will be testing against older
versions of those files - which inevitably leads to confusion. I
either get into the habit of typing
make && prove -rb t
or - if I have no XS code that needs to be built I use the modules
below lib instead
prove -Ilib -r t
So far I've shown you nothing that make test doesn't do. Let's fix
that.
Saved State
If I have failing tests in a test suite that consists of more than a
handful of scripts and takes more than a few seconds to run it rapidly
becomes tedious to run the whole test suite repeatedly as I track down
the problems.
I can tell prove just to run the tests that are failing like this:
prove -b t/this_fails.t t/so_does_this.t
That speeds things up but I have to make a note of which tests are
failing and make sure that I run those tests. Instead I can use prove's
--state switch and have it keep track of failing tests for me. First I
do a complete run of the test suite and tell prove to save the results:
prove -rb --state=save t
That stores a machine readable summary of the test run in a file called
'.prove' in the current directory. If I have failures I can then run
just the failing scripts like this:
prove -b --state=failed
I can also tell prove to save the results again so that it updates its
idea of which tests failed:
prove -b --state=failed,save
As soon as one of my failing tests passes it will be removed from the
list of failed tests. Eventually I fix them all and prove can find no
failing tests to run:
Files=0, Tests=0, 0 wallclock secs ( 0.00 usr + 0.00 sys = 0.00 CPU)
Result: NOTESTS
As I work on a particular part of my module it's most likely that the
tests that cover that code will fail. I'd like to run the whole test
suite but have it prioritize these 'hot' tests. I can tell prove to do
this:
prove -rb --state=hot,save t
All the tests will run but those that failed most recently will be run
first. If no tests have failed since I started saving state all tests
will run in their normal order. This combines full test coverage with
early notification of failures.
The --state switch supports a number of options; for example to run
failed tests first followed by all remaining tests ordered by the
timestamps of the test scripts - and save the results - I can use
prove -rb --state=failed,new,save t
See the prove documentation (type prove --man) for the full list of
state options.
When I tell prove to save state it writes a file called '.prove'
('_prove' on Windows) in the current directory. It's a YAML document so
it's quite easy to write tools of your own that work on the saved test
state - but the format isn't officially documented so it might change
without (much) warning in the future.
Parallel Testing
If my tests take too long to run I may be able to speed them up by
running multiple test scripts in parallel. This is particularly
effective if the tests are I/O bound or if I have multiple CPU cores. I
tell prove to run my tests in parallel like this:
prove -rb -j 9 t
The -j switch enables parallel testing; the number that follows it is
the maximum number of tests to run in parallel. Sometimes tests that
pass when run sequentially will fail when run in parallel. For example
if two different test scripts use the same temporary file or attempt to
listen on the same socket I'll have problems running them in parallel.
If I see unexpected failures I need to check my tests to work out which
of them are trampling on the same resource and rename temporary files
or add locks as appropriate.
To get the most performance benefit I want to have the test scripts
that take the longest to run start first - otherwise I'll be waiting
for the one test that takes nearly a minute to complete after all the
others are done. I can use the --state switch to run the tests in
slowest to fastest order:
prove -rb -j 9 --state=slow,save t
Non-Perl Tests
The Test Anything Protocol (http://testanything.org/) isn't just for
Perl. Just about any language can be used to write tests that output
TAP. There are TAP based testing libraries for C, C++, PHP, Python and
many others. If I can't find a TAP library for my language of choice
it's easy to generate valid TAP. It looks like this:
1..3
ok 1 - init OK
ok 2 - opened file
not ok 3 - appended to file
The first line is the plan - it specifies the number of tests I'm going
to run so that it's easy to check that the test script didn't exit
before running all the expected tests. The following lines are the test
results - 'ok' for pass, 'not ok' for fail. Each test has a number and,
optionally, a description. And that's it. Any language that can produce
output like that on STDOUT can be used to write tests.
Recently I've been rekindling a two-decades-old interest in Forth.
Evidently I have a masochistic streak that even Perl can't satisfy. I
want to write tests in Forth and run them using prove (you can find my
gforth TAP experiments at https://svn.hexten.net/andy/Forth/Testing/).
I can use the --exec switch to tell prove to run the tests using gforth
like this:
prove -r --exec gforth t
Alternately, if the language used to write my tests allows a shebang
line I can use that to specify the interpreter. Here's a test written
in PHP:
#!/usr/bin/php
<?php
print "1..2\n";
print "ok 1\n";
print "not ok 2\n";
If I save that as t/phptest.t the shebang line will ensure that it runs
correctly along with all my other tests.
Mixing it up
Subtle interdependencies between test programs can mask problems - for
example an earlier test may neglect to remove a temporary file that
affects the behaviour of a later test. To find this kind of problem I
use the --shuffle and --reverse options to run my tests in random or
reversed order.
Rolling My Own
If I need a feature that prove doesn't provide I can easily write my
own.
Typically you'll want to change how TAP gets input into and output from
the parser. App::Prove supports arbitrary plugins, and TAP::Harness
supports custom formatters and source handlers that you can load using
either prove or Module::Build; there are many examples to base mine on.
For more details see App::Prove, TAP::Parser::SourceHandler, and
TAP::Formatter::Base.
If writing a plugin is not enough, you can write your own test harness;
one of the motives for the 3.00 rewrite of Test::Harness was to make it
easier to subclass and extend.
The Test::Harness module is a compatibility wrapper around
TAP::Harness. For new applications I should use TAP::Harness directly.
As we'll see, prove uses TAP::Harness.
When I run prove it processes its arguments, figures out which test
scripts to run and then passes control to TAP::Harness to run the
tests, parse, analyse and present the results. By subclassing
TAP::Harness I can customise many aspects of the test run.
I want to log my test results in a database so I can track them over
time. To do this I override the summary method in TAP::Harness. I
start with a simple prototype that dumps the results as a YAML
document:
package My::TAP::Harness;
use base 'TAP::Harness';
use YAML;
sub summary {
my ( $self, $aggregate ) = @_;
print Dump( $aggregate );
$self->SUPER::summary( $aggregate );
1;
I need to tell prove to use my My::TAP::Harness. If My::TAP::Harness is
on Perl's @INC include path I can
prove --harness=My::TAP::Harness -rb t
If I don't have My::TAP::Harness installed on @INC I need to provide
the correct path to perl when I run prove:
perl -Ilib `which prove` --harness=My::TAP::Harness -rb t
I can incorporate these options into my own version of prove. It's
pretty simple. Most of the work of prove is handled by App::Prove. The
important code in prove is just:
use App::Prove;
my $app = App::Prove->new;
$app->process_args(@ARGV);
exit( $app->run ? 0 : 1 );
If I write a subclass of App::Prove I can customise any aspect of the
test runner while inheriting all of prove's behaviour. Here's myprove:
#!/usr/bin/env perl use lib qw( lib ); # Add ./lib to @INC
use App::Prove;
# Use custom TAP::Harness subclass
$app->harness( 'My::TAP::Harness' );
$app->process_args( @ARGV ); exit( $app->run ? 0 : 1 );
Now I can run my tests like this
./myprove -rb t
Deeper Customisation
Now that I know how to subclass and replace TAP::Harness I can replace
any other part of the harness. To do that I need to know which classes
are responsible for which functionality. Here's a brief guided tour;
the default class for each component is shown in parentheses. Normally
any replacements I write will be subclasses of these default classes.
When I run my tests TAP::Harness creates a scheduler
(TAP::Parser::Scheduler) to work out the running order for the tests,
an aggregator (TAP::Parser::Aggregator) to collect and analyse the test
results and a formatter (TAP::Formatter::Console) to display those
results.
If I'm running my tests in parallel there may also be a multiplexer
(TAP::Parser::Multiplexer) - the component that allows multiple tests
to run simultaneously.
Once it has created those helpers TAP::Harness starts running the
tests. For each test it creates a new parser (TAP::Parser) which is
responsible for running the test script and parsing its output.
To replace any of these components I call one of these harness methods
with the name of the replacement class:
aggregator_class
formatter_class
multiplexer_class
parser_class
scheduler_class
For example, to replace the aggregator I would
$harness->aggregator_class( 'My::Aggregator' );
Alternately I can supply the names of my substitute classes to the
TAP::Harness constructor:
my $harness = TAP::Harness->new(
{ aggregator_class => 'My::Aggregator' }
If I need to reach even deeper into the internals of the harness I can
replace the classes that TAP::Parser uses to execute test scripts and
tokenise their output. Before running a test script TAP::Parser creates
a grammar (TAP::Parser::Grammar) to decode the raw TAP into tokens, a
result factory (TAP::Parser::ResultFactory) to turn the decoded TAP
results into objects and, depending on whether it's running a test
script or reading TAP from a file, scalar or array a source or an
iterator (TAP::Parser::IteratorFactory).
Each of these objects may be replaced by calling one of these parser
methods:
source_class
perl_source_class
grammar_class
iterator_factory_class
result_factory_class
Callbacks
As an alternative to subclassing the components I need to change I can
attach callbacks to the default classes. TAP::Harness exposes these
callbacks:
parser_args Tweak the parameters used to create the parser
made_parser Just made a new parser
before_runtests About to run tests
after_runtests Have run all tests
after_test Have run an individual test script
TAP::Parser also supports callbacks; bailout, comment, plan, test,
unknown, version and yaml are called for the corresponding TAP result
types, ALL is called for all results, ELSE is called for all results
for which a named callback is not installed and EOF is called once at
the end of each TAP stream.
To install a callback I pass the name of the callback and a subroutine
reference to TAP::Harness or TAP::Parser's callback method:
$harness->callback( after_test => sub {
my ( $script, $desc, $parser ) = @_;
I can also pass callbacks to the constructor:
my $harness = TAP::Harness->new({
callbacks => {
after_test => sub {
# Do something interesting here
When it comes to altering the behaviour of the test harness there's
more than one way to do it. Which way is best depends on my
requirements. In general if I only want to observe test execution
without changing the harness' behaviour (for example to log test
results to a database) I choose callbacks. If I want to make the
harness behave differently subclassing gives me more control.
Parsing TAP
Perhaps I don't need a complete test harness. If I already have a TAP
test log that I need to parse all I need is TAP::Parser and the various
classes it depends upon. Here's the code I need to run a test and parse
its TAP output
use TAP::Parser;
my $parser = TAP::Parser->new( { source => 't/simple.t' } );
while ( my $result = $parser->next ) {
print $result->as_string, "\n";
Alternately I can pass an open filehandle as source and have the parser
read from that rather than attempting to run a test script:
open my $tap, '<', 'tests.tap'
or die "Can't read TAP transcript ($!)\n";
my $parser = TAP::Parser->new( { source => $tap } );
This approach is useful if I need to convert my TAP based test results
into some other representation. See TAP::Convert::TET
(http://search.cpan.org/dist/TAP-Convert-TET/) for an example of this
approach.
Getting Support
The Test::Harness developers hang out on the tapx-dev mailing list[1].
For discussion of general, language independent TAP issues there's the
tap-l[2] list. Finally there's a wiki dedicated to the Test Anything
Protocol[3]. Contributions to the wiki, patches and suggestions are all
welcome.
[1] <http://www.hexten.net/mailman/listinfo/tapx-dev> [2]
<http://testanything.org/mailman/listinfo/tap-l> [3]
<http://testanything.org/>
ATTRIBUTES
See attributes(7) for descriptions of the following attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | runtime/perl-532 |
|Stability | Pass-through volatile |
NOTES
Source code for open source software components in Oracle Solaris can
be found at https://www.oracle.com/downloads/opensource/solaris-source-
code-downloads.html.
This software was built from source available at
https://github.com/oracle/solaris-userland. The original community
source was downloaded from
http://www.cpan.org/src/5.0/perl-5.32.0.tar.gz.
Further information about this software can be found on the open source
community website at https://www.perl.org/.
perl v5.32.0 2020-06-14 TAP::Harness::Beyond(3)
