CURLOPT_LOW_SPEED_TIME - low speed limit time period
#include <curl/curl.h> CURLcode curl_easy_setopt(CURL *handle, CURLOPT_LOW_SPEED_TIME, long speedtime);
CURLOPT_LOW_SPEED_TIME(3) curl_easy_setopt options CURLOPT_LOW_SPEED_TIME(3) NAME CURLOPT_LOW_SPEED_TIME - low speed limit time period SYNOPSIS #include <curl/curl.h> CURLcode curl_easy_setopt(CURL *handle, CURLOPT_LOW_SPEED_TIME, long speedtime); DESCRIPTION Pass a long as parameter. It contains the time in number seconds that the transfer speed should be below the CURLOPT_LOW_SPEED_LIMIT(3) for the library to consider it too slow and abort. DEFAULT 0, disabled PROTOCOLS All EXAMPLE curl = curl_easy_init(); if(curl) { curl_easy_setopt(curl, CURLOPT_URL, url); /* abort if slower than 30 bytes/sec during 60 seconds */ curl_easy_setopt(curl, CURLOPT_LOW_SPEED_TIME, 60L); curl_easy_setopt(curl, CURLOPT_LOW_SPEED_LIMIT, 30L); res = curl_easy_perform(curl); if(CURLE_OPERATION_TIMEDOUT == res) { printf("Timeout!\n"); } /* always cleanup */ curl_easy_cleanup(curl); } AVAILABILITY Always RETURN VALUE Returns CURLE_OK ATTRIBUTES See attributes(7) for descriptions of the following attributes: +---------------+------------------+ |ATTRIBUTE TYPE | ATTRIBUTE VALUE | +---------------+------------------+ |Availability | web/curl | +---------------+------------------+ |Stability | Uncommitted | +---------------+------------------+ SEE ALSO CURLOPT_LOW_SPEED_LIMIT(3), CURLOPT_TIMEOUT(3), NOTES Source code for open source software components in Oracle Solaris can be found at https://www.oracle.com/downloads/opensource/solaris-source- code-downloads.html. This software was built from source available at https://github.com/oracle/solaris-userland. The original community source was downloaded from https://curl.se/down- load/curl-7.83.1.tar.bz2. Further information about this software can be found on the open source community website at http://curl.haxx.se/. libcurl 7.83.1 November 26, 2021 CURLOPT_LOW_SPEED_TIME(3)
