ne_set_request_body_buffer - include a message body with a request
#include <ne_request.h> void ne_set_request_body_buffer(ne_request *req, const char *buf, size_t count); int ne_set_request_body_fd(ne_request *req, int fd, ne_off_t begin, ne_off_t length);
NE_SET_REQUEST_BODY_(3) neon API reference NE_SET_REQUEST_BODY_(3) NAME ne_set_request_body_buffer, ne_set_request_body_fd - include a message body with a request SYNOPSIS #include <ne_request.h> void ne_set_request_body_buffer(ne_request *req, const char *buf, size_t count); int ne_set_request_body_fd(ne_request *req, int fd, ne_off_t begin, ne_off_t length); DESCRIPTION The ne_set_request_body_buffer function specifies that a message body should be included with the body, which is stored in the count bytes buffer buf. The ne_set_request_body_fd function can be used to include a message body with a request which is read from a file descriptor. The body is read from the file descriptor fd, which must be a associated with a seekable file (not a pipe, socket, or FIFO). count bytes are read, beginning at offset begin (hence, passing begin as zero means the body is read from the beginning of the file). For all the above functions, the source of the request body must survive until the request has been dispatched; neither the memory buffer passed to ne_set_request_body_buffer nor the file descriptor passed to ne_set_request_body_fd are copied internally. ATTRIBUTES See attributes(7) for descriptions of the following attributes: +---------------+------------------+ |ATTRIBUTE TYPE | ATTRIBUTE VALUE | +---------------+------------------+ |Availability | library/neon | +---------------+------------------+ |Stability | Volatile | +---------------+------------------+ SEE ALSO ne_request_create AUTHOR Joe Orton <neon@lists.manyfish.co.uk> Author. COPYRIGHT NOTES Source code for open source software components in Oracle Solaris can be found at https://www.oracle.com/downloads/opensource/solaris-source- code-downloads.html. This software was built from source available at https://github.com/oracle/solaris-userland. The original community source was downloaded from http://www.webdav.org/neon/neon-0.30.1.tar.gz. Further information about this software can be found on the open source community website at http://www.webdav.org/neon/. neon 0.30.1 23 September 2014 NE_SET_REQUEST_BODY_(3)
