TAP::Base - Base class that provides common functionality to TAP::Parser and TAP::Harness
package TAP::Whatever;
use base 'TAP::Base';
# ... later ...
my $thing = TAP::Whatever->new();
$thing->callback( event => sub {
# do something interesting
Perl Programmers Reference Guide TAP::Base(3)
NAME
VERSION
Version 3.42
SYNOPSIS
# ... later ...
DESCRIPTION
"TAP::Base" provides callback management.
METHODS
Class Methods
"callback"
Install a callback for a named event.
"get_time"
Return the current time using Time::HiRes if available.
"time_is_hires"
Return true if the time returned by get_time is high resolution (i.e.
if Time::HiRes is available).
"get_times"
Return array reference of the four-element list of CPU seconds, as with
"times" in perlfunc.
ATTRIBUTES
See attributes(7) for descriptions of the following attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | runtime/perl-532 |
|Stability | Pass-through volatile |
NOTES
Source code for open source software components in Oracle Solaris can
be found at https://www.oracle.com/downloads/opensource/solaris-source-
code-downloads.html.
This software was built from source available at
https://github.com/oracle/solaris-userland. The original community
source was downloaded from
http://www.cpan.org/src/5.0/perl-5.32.0.tar.gz.
Further information about this software can be found on the open source
community website at https://www.perl.org/.
perl v5.32.0 2020-06-14 TAP::Base(3)
