puppet-help - Display Puppet help.
puppet help action
PUPPET-HELP(8) Puppet manual PUPPET-HELP(8) NAME puppet-help - Display Puppet help. SYNOPSIS puppet help action OPTIONS Note that any setting that's valid in the configuration file is also a valid long argument, although it may or may not be relevant to the present action. For example, server and run_mode are valid settings, so you can specify --server <servername>, or --run_mode <runmode> as an argument. See the configuration file documentation at https://pup- pet.com/docs/puppet/latest/configuration.html for the full list of acceptable parameters. A commented list of all configuration options can also be generated by running puppet with --genconfig. --render-as FORMAT The format in which to render output. The most common formats are json, s (string), yaml, and console, but other options such as dot are sometimes available. --verbose Whether to log verbosely. --debug Whether to log debug information. ACTIONS help - Display help about Puppet subcommands and their actions. SYNOPSIS puppet help [--version VERSION] [--ronn] [subcommand] [action] DESCRIPTION Display help about Puppet subcommands and their actions. OPTIONS --ronn - Whether to render the help text in ronn format. --version VERSION - The version of the subcommand for which to show help. RETURNS Short help text for the specified subcommand or action. EXAMPLES help Get help for an action: $ puppet help COPYRIGHT AND LICENSE Copyright 2011 by Puppet Inc. Apache 2 license; see COPYING ATTRIBUTES See attributes(7) for descriptions of the following attributes: +---------------+--------------------------+ |ATTRIBUTE TYPE | ATTRIBUTE VALUE | +---------------+--------------------------+ |Availability | system/management/puppet | +---------------+--------------------------+ |Stability | Volatile | +---------------+--------------------------+ NOTES Source code for open source software components in Oracle Solaris can be found at https://www.oracle.com/downloads/opensource/solaris-source- code-downloads.html. This software was built from source available at https://github.com/oracle/solaris-userland. The original community source was downloaded from https://github.com/puppetlabs/puppet. Further information about this software can be found on the open source community website at http://puppetlabs.com/. Puppet, Inc. January 2022 PUPPET-HELP(8)
