Monitor an Original PDU (LCD Screen)
You
can
check the
current being used by equipment attached to a PDU by viewing the
PDU's metering unit LCD screen.
Locate the PDU you want to monitor in the rack.
You might need to open the rack's rear door to access the PDU.
Locate the metering unit on the PDU.
You can find the metering unit in the middle of the PDU.
Check the metering unit's LCD screen to view the current being used by the
equipment connected to each PDU module.
The LCD screen displays the
amp measurements of all of the phases of a single PDU module.
See Understanding the Relationship Between Modules and Outlet Groups for a
description of PDU modules.
If your PDU has more than one module, press the
reset button to cycle through the available
modules.
For easier viewing, you can rotate the screen in 90-degree
intervals by pressing the reset button for longer than 1 second. See
Adjust the LCD Screen (Original PDU) for more
information.
1
2
Measured amp reading of the current being used
by the equipment connected to the PDU phase
3
Abbreviation for amperes (amps)
4
Metering unit phase number
