Help Commands
After successful login, you can use different commands at the CLI prompt.
Starting with FW 2.02, typing help or ? at the command prompt
provides a list of covered topics. The list of covered topics might be different between
firmware releases.
pducli -> help
<list of provided topics based on firmware version>
Table 16 List of Covered Topics for the help Command
PDU-SystemInfo
pducli -> help
PDU-SystemInfo
NetworkServices
pducli -> help
NetworkServices
NetworkPorts
pducli -> help
NetworkPorts
IPv4-Configuration
pducli -> help
IPv4-Configuration
IPv6-Configuration
pducli -> help
IPv6-Configuration
Host-Configuratoin
pducli -> help
Host-Configuration
User-Configuration
pducli -> help
User-Configuration
SystemTime
pducli -> help
SystemTime
PowerInfo (Total PDU)
pducli -> help PowerInfo (Total
PDU)
PowerInfo (Inputs)
(Inputs)
PowerInfo (Lines)
(Lines)
PDU-EventList
pducli -> help
PDU-EventList
Each topic contains a list of valid commands for the PDU. To get a list of valid
commands for a topic, type:
pducli -> help topic- name
Note -
Some commands are restricted to accounts with admin privileges only.
To get help on a specific command, type:
pducli -> help command-name
This command provides information on how to use the command in the format:
pducli -> help command-name parameter value <(if applicable)>
