Configure SNMP Traps
Use
the
HTML
interface to specify SNMP trap hosts, trap options, and test trap
configurations.
Note -
Screenshots with the reset functionality are from FW version 2.01. The
reset functionality is not available beginning with FW version 2.02.
Access the PDU metering unit from a system on the network.
See Access a Metering Unit on the Network (Enhanced PDU).
Click on the Net Configuration link and log in as an admin user.
Select the SNMP-Traps tab.
Define up to ten SNMP trap hosts then click submit.
Once configured, the Metering unit sends SNMP traps to the hosts that are
enabled. For each host enter the IP address or host name and community name.
Select the SNMP trap version and check the enable box for traps to be sent
to this host. If v3 SNMP traps are selected, select the user associated with
this host.
Provide values to the repeating trap settings.
Here is a description of these repeating trap settings.
The number of seconds between repeating the
KeepAlive trap.
0 - 60
Repeating Time for Traps
s between sending trap messages to SNMP
hosts.
0 - 60
Number of traps
The number of times the same trap can repeated to the
same host.
0 -255
Click the Submit button to enable these SNMP settings.
Send a test trap to verify the SNMP settings.
