Types of PDU Metering Unit SNMP Traps (Enhanced PDU)
The following table describes the
SNMPv2 traps the metering unit can send to SNMP agents on
the network (over UDP port 162). In the
trap descriptions,
InputNum/LineNum
corresponds to the input number and line number of the PDU (for example,
Input1/Line2).
Note -
The InputNum for SNMP Traps start at 1, not 0.
Keep alive
KeepAlive-Trap
The PDU sends a KeepAlive-Trap
message to the SNMP host to ensure that the link between them is
operational.
Dead
Dead-Trap
Sent after a PDU power cycle.
Current Info
Info-Trap on
InputNum/LineNum
Attached equipment is using less current than expected.
Current Warning
Warning-Trap on
Input Num/Line Num
Attached equipment is using more current than expected.
Current Alarm
Alarm-Trap on
InputNum/LineNum
Attached equipment is using a critical amount of current and
requires immediate attention.
Current Out of balance
OutOfBalance-Trap on
InputNum/LineNum
The equipment attached to one phase is using more current than
the other phases on the input. The PDU and attached equipment
require immediate attention.
Current Return to normal
ReturnToNormal-Trap on
InputNum/LineNum
After sending an alarm trap, the attached equipment has
returned to using the expected amount of current.
Voltage Warning
Warning-Trap on
InputNum/LineNum
Attached equipment is operating with undesired but acceptable
voltage level.
Voltage Alarm
Alarm-Trap on
InputNum/LineNum
Attached equipment is operating with an unacceptable voltage
level.
Voltage return to normal
InputNum/LineNum
Attached equipment is operating with an expected voltage
level.
