Use the HTML interface to enable SNMP, specify SNMP community hosts, and set repeating SNMP trap durations.
You are prompted to log in as an admin user. By default, both the admin user name and password is admin.
If desired, you can disable HTTP access to the PDU by deselecting the HTTP enable checkbox located just above the SNMP heading.
Once configured, the metering unit sends SNMP traps to these hosts. For each host, type in the IP address and the SNMP community name. An SNMP community name identifies which SNMP group the host belongs.
Here is a description of these repeating trap settings.
