Reset the PDU Metering Unit (Original PDU)
You can reset the PDU metering unit using the reset button.
Note -
Resetting the metering unit does not power cycle equipment attached to the
PDU.
Press and hold the reset button until you see a five-second countdown
displayed on the LCD screen.
You must press
the
reset button for 20
seconds before the five-second countdown begins.
During the five-second countdown, release the reset button and then tap
the button again to force the metering unit to reset.
