Monitoring Original PDUs
The original PDU metering unit allows you to monitor the current being used by equipment
connected to a standard PDU. You can monitor the current in person by viewing
the LCD screen on the PDU itself or remotely from a system on the network.
Using the metering unit's HTML and SNMP interfaces, you can set threshold and alarm levels
that you can monitor remotely. You also can configure the metering unit to send messages to
systems on the network.
Note -
Compact PDUs do not contain metering units, so you cannot monitor the current of
equipment connected to them.
The following table lists the tasks necessary to configure and use the PDU metering
unit.
Understand the relationship between the metering unit interface and
the PDU outlet groups.
Access the metering unit from a system on the network.
Set the amperage threshold alarm values.
Monitor the amperage levels.
Change the metering unit interface settings.
Enable and configure SNMP settings.
View the metering unit firmware version and update the
firmware.
Use the PDU metering unit's LCD screen.
Restore the PDU metering unit's settings back to the factory default
settings.
