Go to main content
Sun Rack II Power Distribution Units User's Guide
Exit Print View
Updated: September 2020
Login Information
To log in to the PDU metering unit, you will type the user name (admin or user) and the password. Determine the password for your user name based on your firmware version.
Only one admin or user can be logged into the metering unit at a single time.
  • admin – admin users can view all pages and configure all settings.
  • user – for original PDUs, users can view the Current Measurement and the Module Info pages and set the thresholds on the Param Configuration page. For enhanced PDUs, users can view the Metering Overview and Module Info pages and set the thresholds on the Parameter page. See Add Users and Change Passwords (Original PDU) for original PDU instructions. See Add Users and Change Passwords (Enhanced PDU) for enhanced PDU instructions on adding users.
PDU Type
Minimum Firmware Version
User Name
Password
Original PDU
1.00
admin
admin
Original PDU
1.06
admin
adm1n
Enhanced PDU
2.00
admin
adm1n
You should change the password after configuring the network.
