Compact PDU Installation Locations
You can install up to six compact PDUs, three per side, in a Sun Rack II cabinet.
Secure the compact PDU to the rack frame using the two mounting brackets that
shipped with the PDU. While these mounting brackets permit you to install the PDU
anywhere on the rear rack frame, install new compact PDUs from the bottom of the
rack up. The following figure and table display the compact PDU installation
locations and spacing on the rear rack rail.
Note -
Once installed, it is challenging to reposition a compact PDU in the rack. If
you are installing only one compact PDU, install it at the bottom of the rack to
leave room for additional compact PDUs.
Table 10 Compact PDU Locations on the Rear Rack Frame
3
Top of third PDU top mounting bracket
1775 mm / 69.88 in.
Bottom of third PDU
1220 mm / 48.03 in.
2
Top of second PDU top mounting bracket
1210 mm / 47.64 in.
Bottom of second PDU
655 mm / 25.79 in.
1
Top of first PDU top mounting bracket
645 mm / 25.39 in.
Bottom of first PDU
90 mm / 3.54 in.
